wolfetek said:Does anybody use copper tubing for thier cooling system? It seems like it would help to cool the water down alot better.
juliendogg said:
to point out the obvious, for the copper tubing to help cool the water, the air temp around the tubing would have 2 be lower than the water temp in the tubing. check your temps, i think you'll find that if your rad is working properly, the in case temp will be above or close to the temp of the water. would be different if you were running the copper tubing through something refridgerated eh?
