- Jul 8, 2012
copy "windows files" from another windows 7 drive to fix starup on safe mode.
I've noticed that my windows 7 OS has been often asking for check disk to run at startup. It never results in any errors/findings... but is annoying with the frequency of it. I've tried running sfc /scannow, tried running startup repair from my Windows 7 installation disk. I don't have a restore point prior to this problem to fix it. Something must be up. I've also noticed while trying to fix the problem, I can't boot into safe mode, it loads drivers looks close to be coming up and then just reboots before desktop appears, no BSOD or errors posted... tried full virus scans and with malware-bytes with nothing showing up. Really don't want to do a new finish install on this drive and deal with getting all my programs/settings back the way I want them.... I have a 2nd drive and from the same installation disk(on usb stick), thought of having a fresh copy of windows installed and then from a linux os copying over windows files to attempt to fix the problem.. Anyone tried this before or any advice in this or warnings attempting? While I do have Windows 10 on another drive, I'm really nostalgia of keeping this OS going.
O yes, forgot mention I did disable my overclock even though its been stable for over a year, just to make sure that wasn't it.
