- Nov 7, 2002
- Perth, Australia
Well... after much advise from people already on the forum I went home, took off the heat sink, removed the sensor of my volcano 9 and set it to full ball.
I've reseated it twice now, both times taking the sink off to ensure that there was a nice even square of that cooling gel {not too much mind you} to ensure that it fully covers it.
In the mean time I switch the little OVER_VOLT1 jumper on my A7V8X to allow my to set the voltage ranges from 1.75 to 2.05 (in the "disabled" setting it allows range from 1.5 to 1.75).
I boot it back up, all works fine, I go to check the temp to see if its helped...
At IDLE my machine now says its running at 60 degree's {Asus probe}!!!! I didnt believe it, so I downloaded motherboard monitor. Sure enough, it took says 60 at idle. Checked the BIOS Hardware monitor {needed that little bit of extra proof}, and yeap. 60 degree's, IDLE!
Then I noticed it...
The VCore is reported to be at 2.05!! On both AsusProbe, Motherboard monitor AND the BIOS hardware monitor. I checked the BIOS CVoltage setting, yeap, its still at 1.75.
Um, yeah. So anyway, at this point I freak, turn the computer off. Switch the little jumper back to Disabled. I turned the computer back on, oh goodie, the idle temp is now at 52degree's and the Vcore is at 1.856 (again the BIOS says its still set too 1.75)
I thought XP2000+'s were supposed to be set by default to 1.75? Thats what the BIOS in my motherboard says anyway.
I guess this is whats causing the large amount of heat. My CPU is defaulting to a higher Core Voltage.
Anyone else heard of this happening? Any ideas on what I should do or should I just leave it and pray?
And yes, I found a 250PSU powersupply to be less than adequate. On full bore {the Volc 9 sits at 5324rpm} I get tiny little power spikes. I'm afraid to even turn my computer back on now with everything thats going on
