Coretemp shows i5 750 (Lynfield) (ES)
Brutal-Force
I pulled up that ES means Engineering Sample.
In Wikipedia it says that this is a beta chip and that ES Chips are usually desirable.
Is this what I see in the FS: threads as Extra Spicy?
And what does this really mean to me?
ES does not always mean better. Especially if the chip has been through a stepping change. Each chip is linked to a specific engineer, they are not allowed to sell them. If Intel gets a hold of the serial number and traces the chip back to the engineer that let it leave their possession, then bye-bye job. And I supposed they could confiscate the chip, as it's Intel property... thus not allowed to be sold.
That's why they're usually listed as Extra Spicy
Hrm, maybe I should in fact pop out 4 Gigs of ram to see how far this puppy will go.
ES used to mean greatness, not so much anymore these days.. I have an ES E8600 that is a pig for voltage, needing more then most C0's :D
I think it is interesting that your chip does not show ES in CPUZ only in CoreTemp. I have two ES chips and they are both identified as ES in CPUZ.
Well I do have the HT [enable/disable] option, but the i5 doesn't have hyperthreading right?
The box it came in says i5 750. :shrug:
Yeah I downloaded the lastest version.
Does everyone with an i5 750 also have a option to enable/disable HT?
No, i5 750s do not have HT. If CPU-Z doesn't say it's an ES, the odds are good it's a retail chip and CoreTemp is wrong. I've seen retail i7 chips that are identified as "ES" chips in CoreTemp.
Update: I didn't have the latest version of Coretemp. After I updated it no longer said ES.
As for the HT portion, I don't understand why MOBOs give you this option even if the chip doesn't support it. AND what happens if you enable it.
"If you enable HT on a i5 maybe you can travel backwards in time."
very stable setup
Fri, 01 Jan 2010 06:24:44 +0100 | Validated by EVGA Validator 1.01
CPU PSN : hOUDM sbNSD ulHbqtafi[
CPU EXT : MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 EM64T
CPUID : 6.E.5 / Extended : 6.1E
CPU Cache : L1 : 4 x 32 / 4 x 32 KB - L2 : 4 x 256 KB
CPU Cache : L3 : 8192 KB
Core : i5 750 (45 nm) / Stepping : B1
Freq : 3800.08 MHz (200 * 19)
Rated Fsb:3600 Mhz
MB Brand : EVGA
MB Model : EVGA P55 SLI LE E653
NB : Intel DMI Host Bridge rev 11
SB : Intel PCH LPC Bridge rev 05
here is mine
RAM : 6144 MB DDR3 Dual Channel
RAM Speed : 800 MHz (2:8) @ 8-8-8-24
CPU-Z Forum Banner (BB Code below)
