- Oct 31, 2009
- California
The Rheobus is a manual fan speed controller, there is no PWM speed control involved whatsoever.
Personally, I would just go with a manual model. I leave mine on the lowest sustainable setting and it's always been plenty with my fans, and the noise level is bearable.
Thanks. I may end up doing what you suggest, because a manual model is pretty cheap and I can always upgrade later on if I need to. I might even try to get one used off eBay.
