I think I am going to try it out, when I order all my WC stuff. Is it liquidy out of the box, or is t a solid until you do the reflow thing where you heat it up with your cpu?
Edit: And nah, I don't really think I will be removing my heatsink at all once i get everything all installed.
Skalm? Can I ask how many times you have redone TPaste on CPU and GPU chips? Many first time watercoolers have enough issues without the added problems IX can cause. Some take at least TWO applications of IX to get it right the first time. And those are folks with many remounts. I'd like to try it myself, and over the last 18 years or so I've done ohh 50+ remounts, and I still don't feel the need for a small decrease in temps for the hassle of IX.. You
really really should build the loop with conventional Tpaste first. It's your stuff and you live with your mistakes.
If you have quality Tpaste already, use it instead of the IX. You can easily redo it later once your rig is stable, bled, no leaks etc.
If you don't have any quality paste, toss a tube of MX-2 in the order, it isn't that much.
And you hade some questions about gromets, seals etc etc. Every rig is different, we can't advise you on everything. Nor can we come to your house. For many many of the small things your on your own, your brain and you will make it work.
Once your ready to order, take a screenshot of the order (S), size it down to a decent size and post it here. I had to use 3 stores for my very first WC loop. Do the best you can, and pay attention to shipping. A $3 part saving for $8 more shipping no workie.
