So I'm planning out my first water cooling loop for my system that I just recently migrated into a Corsair Air 540 from my Corsair 700D. I have a pretty good idea of how the layout of everything will be but I am more than open to critiques and suggestions. As it stands right now the only thing in my loop will be my CPU... possibly the RAM but I'm still out on that one.
Unfortunately as it stands right now there is no full-cover water block for my Gigabyte GTX 770 Windforce 3 OC since it is a non-reference pcb but hopefully someone will make one soon and it will be added into the loop as soon as I can.
So my current idea for my loop would be to go from the 1) Reservoir, 2) Pump, 3) 360mm Radiator (intake), 4) CPU, 5) 240/280 Radiator(exhaust) and then returning to the reservoir to complete the loop. The fittings for the 360mm radiator would be at the bottom more than likely to allow the best possible clearance of the top radiator. Then the 240/280mm radiator would have its fittings at the back of the case for the same reason pretty much. I'm still deciding on whether to do rigid acrylic or rubber tubing, but leaning more towards rigid acrylic to allow for the look I am envisioning in my head. Also the 2x 3.5" base in the bottom of the case are going to be removed, holes covered, and the two 3.5" storage drives currently occupying that space are going to be replaced by a single 2.5" 1Tb SSHD so it can be installed in the second compartment of the case.
The image below lists the components I have for sure decided on plus a rough layout of the major components. Also any suggestions are welcome especially regarding the radiators as I am still completely undecided on those at the moment.
