Corsair memory help?
redduc900
Inactive Moderator
Portland, OR
Assuming a default BCLK of 133MHz, change these settings...
Code:
Memory Frequency: 1601MHz
DIMM Voltage: 1.5 - 1.55
tCL Setting: 9
tRCD Setting: 9
tRP Setting: 9
tRAS Setting: 24
redduc900
Inactive Moderator
Portland, OR
Fill out this BIOS template for the Classified w/ all of your current settings (disregard the settings in the template, and replace w/ your own)...
Code:
Frequency Control
CPU Clock Ratio ( 20X )
CPU Host Frequency (Mhz) ( 133 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( Auto )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature
Memory Speed ( XMP Profile 1 )
Memory Control Setting ( Enabled )
Memory Frequency ( Auto -> 1600Mhz )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 9 )
tRCD Setting ( 9 )
tRP Setting ( 9 )
tRAS Setting ( 24 )
tRFC Setting ( 88 )
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( With VDroop )
CPU VCore ( Auto )
CPU VTT Voltage ( Auto )
CPU PLL VCore ( Auto )
IOH PLL VCore ( Auto )
DIMM Voltage ( 1.50 )
DIMM DQ Vref ( +0mV )
QPI PLL VCore ( Auto )
IOH VCore ( Auto )
IOH/ICH I/O Voltage ( Auto )
ICH VCore ( Auto )
PWM Frequency ( 800 Khz )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Enabled )
Virtualization Technology ( Enabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( Auto )
OC Recorvery ( Disabled )
PnP/PCI     PCI Express
Maximum Payload Size ( 128 )
Yellowbeard XMS
Official Corsair Tech Support
You are going to have a hard time getting 6 modules to OC much due to the load on the memory controller. You will definitely need to increase the memory controller voltage to have any hope of it. Also, those are 1333 modules. If you want to be guaranteed of 1600, you need to purchase 1600 modules.
Try 1.4v on your memory controller and see if that helps.
coco16
coco16
Miami,FL
they are 1333mhz memory but most of the memory can be oc also i know with 6 modules its hard anyways thx im going to try the 1.4v on memory controller
thx.
coco16
coco16
Miami,FL
i was looking at mobo setting and idk which one is the memory controller setting bc it has tons of settings can someone help me finding this thx.
MOBO: evga e760
