Corsair ML120 Pro LED, Blue, 120mm Premium Magnetic Levitation Cooling Fan
efilloon
Has any used the "Corsair ML120 Pro LED, Blue, 120mm Premium Magnetic Levitation Cooling Fan CO-9050043-WW" fan with a fan controller, if so what fan controller did you use? What fan controller does work with this fan?
Lochekey
Senior Pink Member
I run one of these fans of of a fan header on my mono. Be aware that whatever controller you go with it needs to be pwm controlled. The fans need a constant 12v to operate correctly and will not work on a voltage adjustment controller.
