I know that Corsair Vengeance 2x4GB DDR3-1600 is not a new memory kit but I've never tested one before on the OCF. Since I was installing one of these kits at work and I could test it then I thought I will add some results.
There is only one XMP profile as in most DDR3-1600 kits what is of course enough.
Results at XMP settings are below. There is also AIDA64 table with timings.
XMP is in 1.2 version so I assume it wasn't manufactured lately. However there is no info about manufacture date. Number on the sticker - 5.13 suggests there can be Hynix memory. Two 4GB modules are double sided so it's also a sign that tested memory isn't from any newer series as all manufacturers moved to higher density chips some time ago.
