Recently I had no chance to test Corsair memory so when I had to buy additional kit for home PC then I decided to check one of the new Vengeance LED kits. I've picked 2x8GB 3200 CL16 kit with white LEDs which you can find under the CMU16GX4M2C3200C16 product number.
Memory comes in small box as we are used to see in most memory series. There is nothing additional like stickers, only two memory modules but we don't need anything else.
Tested Vengeance LED kit has one XMP profile which is working without issues on ASRock Z170 OC Formula. Memory is based on lower density Samsung IC so about the same as we could see in older DDR4 kits. 8GB modules are dual rank / double sided. Some of the overclockers already know there are better memory kits for competitive benchmarking but I guess that gamers or modders are still interested in this memory, not only because of LEDs.
