Cosair 850HX Modular...possible problem
NS13Stinger
Gray, GA
I have a Cosair 850HX Modular psu and an EVGA P55 FTW SLI motherboard. Was checking out the huge poster that came with the motherboard showing all the connections and noticed there are two 8-pin 12v connectors at the top left of the board. EVGA states that both connections are "recommended" in order to overclock.
My psu only has one 8-pin 12v cable/connector. Possible problem here?
otogrim
Houston, TX
Unless you're going to be overclocking it like crazy you really will only need one connected. But if you really want both I think it comes with a converter so you can just use the other molex on ur psu
