- Mar 8, 2012
- Perth - Western Australia
Firstly I would like to thank all of those who took the time to reply to my "feedback" thread (http://forums.overclockers.com.au/showthread.php?t=1016239) which got almost 90 replies; all of your suggestions has been considered in the finalisation of my watercooling orders.
FrozenCPU package contents:
-Black Ice GTX Extreme 240
-Black Ice GT Stealth 360
-Alphacool VPP655 pump + Bitspower pump mod kit (Chrome)
-Koolance 370 cpu block
-Koolance R4E mobo block
-Koolance TNK-501 single bay reservoir
-Primochill PRO LRT 3/8" - 5/8" tubing
-IandH Dead Water Copper Sulfate Biocidal additive
-ModRight Mod Mat
So my package from FrozenCPU arrived Thursday arvo and I thought I should get the ball rolling and start the installation of key components. I spent the afternoon and early Friday morning+evening installing the Koolance mobo water block, CPU, RAM, CPU waterblock, 6x 45degree compression fittings onto the blocks, motherboard into the case, bottom Black Ice GTX Extreme 240 rad in the bottom, PSU, GPU, and soundcard.
Came across some issues, and worked around them, further issues came up and I am yet to get around to them and I am willing to take on-board the suggestions, solutions and possibly hands-on help from the community (anyone around Riverton-Perth? haha).
So, it all began with the ModRight mat, which I do recommend for anyone.
First things first, I had to remove the stock heatsinks and replace them with the Koolance blocks:
Next, installed the CPU, CPU block and then the RAM:
Now, get the compressions onto these blocks:
Now to get the board into the case:
GPU into first 16x PCIe3:
Installing the X-Fi Titanium; now the instruction manual says that you can plug it into a full length PCIe slot, but the card only has these two plug-in points:
I wasn't sure if I could just plug it into the next PCIe3 8x slot here(yellow) or here(blue):
I was thinking if I had been running dual-GPU I would have to plug it into the "yellow" socket otherwise the 2nd GPU wouldn't fit into the second 16x PCIe3 slot; but seeing as it fit the PCIe2.0 x1_1 slot perfectly I decided to leave it there...can someone shed some insight into this? Is it normal to plug it into a full length PCIe 3.0 slot or would it only work where I currently have it installed? Currently it is in here:
Also you might not notice in this picture but when the computer is placed upright the GPU seems to be so heavy that the card is actually on a slight slant towards the back..is this normal? I don't remember any other GPUs I've installed to have such a bend near the back of the card; then again I've always used reference cards up until this point, maybe the non-reference Gigabyte cards are not as rigid??
Next came the Black Ice GTX Extreme 240 radiator for the bottom mount:
Now this is where the next issue came up due to me not using normal 25mm thickness fans. The Ultra Kaze's are 38mm thick, and the screws provided with the rad is catered for 25mm fans so I had to go to Searle Fastenings in Riverton to get 40mm versions of the exact same threaded screws:
So this proved to be the exact length I needed to mount my 2 push Ultra Kaze's, but proved to be too short for the 2 pull Ultra Kazes at the other side, because there was an additional layer (rad bracket) of a couple of millimetres the screw had to go through.
So back to Searle Fastenings it was to get 8 of the same screws but this time 50mm lengths. Now you might start to say "err 50mm is way too long it will hit the fins", I knew this so I also purchased about 80 plastic washers to match the screws. Fitting 10 washers each screw compensated for about 9mm of excess length I had to get rid of which meant I didn't have to hacksaw them off. I might add it doesn't actually look as bad as I imaged it to either.
Here's a shot of the rad installed with the two 90degree rotary compression fittings:
At this point I was well tired and about ready to call it a day, but I thought I should investigate the roof of the case to see how I would go about installing my Black Ice GT Stealth 360 radiator. I was under suspicion that the "hooks" on the inside of the case (that hold up the front-most top fan in junction with 2 screws) will be in the way of mounting the rad, and after investigating I realised that was the case. So I just got a nice robust pair of pliers and bent those "hooks" flat into the roof seamlessly:
The "hooks" are those two front bits that are slightly scratched up. The scratches don't bother me as the front sliding mechanism covers that area completely anyway.
After dealing with those "hooks" I could line up the radiator to get a ball-park idea of where it will go, and upon doing so I realised another problem:
(might not be visible in pictures)
Basically what is happening here is (I know it's hard to see in these pics), after I line up the first two thread holes of the rad, there is a gradual misplacement of the bracket mounting holes on the Cosmos 2. I don't know how to describe it but what I'm trying to say is, if I line up the first two holes, then the last 2 holes are too far along to be able to mount all of the fans in their corresponding 4-hole configs. Does that make sense?
So what I was thinking is that I need to extend the mounting holes on the Cosmos 2 to be able to mount the radiator, but I don't know how...
First thing that came to my mind is filing the holes across to allow access to the thread holes, or using a Dremel but I don't have such a tool, and I don't really feel like removing the motherboard, but I will if I have to.
I've ordered 3x Gentle Typhoon 3000's to go with the rad. These are the standard 25mm thick fans...because I don't want to deal with custom screws and washers again lol.
After examining the rest of the stuff from FrozenCPU, I had a look at the tubing. I got the Primoflex PRO LRT 3/8" - 5/8", and corresponding Bitspower compression fittings. I got one of the fittings and tried to fit it onto the tubing, but for the life of my I couldn't get the tube to go over the inner barb. The tube is massively thick walled... I don't think it can physically fit the fittings that I have...or am I just weak? lol
Here's a shot of the tube and the compression fitting:
Judging by the looks of it it's supposed to fit... but I can't get it on for the life of me and I promise I'm not weak! haha
I will be sure to update the log as I get more stuff done.
-ModRight Mod Mat
