- Apr 12, 2002
I have been planning watercooling my PC for some time now. I have finally settled on this case http://www.directron.com/9804.html .
For the watercooling components I was going to buy my pump and Radiator @ BEcooling and my Waterblock, Tubing, and clamps @ Cooltechnica. Here are a list of the components:
Maze3 Waterblock- [email protected]
7ft of 1/2ID Tubing- $.5/[email protected]
Via Aqua 1300 W/ fittings- [email protected]
Heatercore w/ [email protected]
I was thinking of replacing the pump with a MaxiJet 1200 but i want this to be an inline system and those are supposed to be a submerged pump. Am I wrong? What is the lowest price for this pump?
I am also willing to replace the Waterblock with anything cheaper with comparable performance (Maybe a pop can block but I am a little weary of mounting it).
Where would be the best place to buy fittings for the heatercore if i wanted to build my own?
Thanks.
Thanks.
