- Sep 9, 2005
- Kauai, Kapaa, HI
Aloha all,
I am not new to PC Cooling, i dont know what the deal is here.
Test setup
C2D e6420 OC 3.4Ghz 1.41Vcore
Cooler Thermalright Ultra 120 - Extreme
Problem 2 x Prime 95 Temps are 70+
idle temps 39c - 41c
Ambent temp: 80 - 85
I read all of the reviews, this is the best air cooler blah blah blah....
I installed it with the LGA775 mount and used Arctic silver 5
I used a small amount, like the size of a piece of rice and spread it all out.
load temps are very high 70c with fan on low and 62 - 66 with fan on high
Low fan setting is 1200rpm high is 3800 rpm
When i put my hand on the heatsink it was luke-warm if that. Why would the temps be so high when the darn thing is barly hot?
You cant screw up the mount as its very strait forward
The only after market cooler i have ever found good with the thermaltake heat towner all copper , forgot the modle number but that thing rocked, when it got hot you knew it was working....
-I am so confused...
Test setup
