couple of questions on air cooling
a1cnolan
georgia
okay couple of questions..
best kind of fan for AX-7.. i read an article saying it liked low cfm.. why would that be. i know it does better with the fan blowing on it but i need to be able to cool my processor better. my case temps are about ambiant but i want to get my processor temps down.
also...
how do i get accurate readings of my temperatures. ive read a lot on how motherboards are innacurate. so how do i read my temps accurately and how much is it going to cost me.
any ideas on how to get my cpu temps lower. i know i need some artic silver but what else can i do.
cypher
Richland, WA
Actually the Ax-7 will cool the best with the highest cfm fan you can stand. I have one on a Gigabyte board with an XP 2100+ using a Smart fan 2. It keeps temp to about 43C at full load. For temp monitoring. You can use something like the Digital Doc 5 wich will let you directly read the Cpu die temp. Or with newer motherboards that directly read the internal CPU temp.
toastedzergling
AX-7 is the best heatsink for low cfm, low noise, undervolted fans. (better than slk 800), probably due to its sheer size, when it comes to tornados or delta screamers, SLK800 is the best
