- Mar 20, 2005
Hello,
Lets imagine three situations:
1)You have two hard drives in your PC. Drive A contains Windows installation and other files. Drive B is an empty drive. Your Motherboard supports RAID 1(additionally 0 and 5) and you want to setup hardware RAID 1.
Is it possible to switch HDD to RAID mode, enter RAID BIOS, create array using drive A, copy drive B content to drive A and run RAID 1 using two drives(drive A should rebuild array on next restart and copy mirror drive A on drive B)
2)You have two drives, drive A and drive B running in hardware RAID 1.
You need to format drive B, copy drive A's content oto drive B(which should be non-raid drive now) and install non-raid drive B on another PC.
3)You have three drive A, B, C.
Drive C contains Windows and other files. You need to setup RAID 1 using drive A and B and then copy Windows from drive C to newly created array consisting of drive A and B.
All three scenarios require no Windows re-installation.
Can anyone please post step by step tutorial for all three scenarios or point to already posted appropriate tutorials?
