- Jan 26, 2001
WyrmMaster (Jul 13, 2001 04:47 p.m.):
The deltas rpm might increase because of the suction, but it wont hurt anything. When i was using my FOP 32 i had an 80mm fan piggiebacked ontop of my YS Tech fan. Increased RPM by about 700, and droped temps slightly. They where both blowing down on the heatsink, but same basic consept.
I would recommend not sealing the duct up tight against the 120mm. The delta pushes 38cfm at max rpm, the 120mm probably pushs between 70 and 100 cfm. If it was sealed up it would slow the 120mm down significantly.
THKS there Wyrm...i will try it...always have to try to find out new things
