Cpu Cooler And Thermal Compound
Gosu
SORRY GUYS
THIS IS ONE QUESTION
I HAVE ATHLON XP1800 AND XP1900
WHAT IS THE BEST CPU COOLER I CAN BUY FOR OVERCLOCK MY PROCESORS
I SEE IN THE NET VOLCANO 7, DRAGON ORBITAL 3, MILLENIUM GLACIATOR,THERMAL AX-7, PAL8045, COOLERMASTER HHC-001
ETC.
WHAT IS THE BEST CPU COOLER???
AND THE BEST THERMAL COMPOUND???
I HAVE XP1800 @1.66GHZ my temp is 50C normal and full load 59C
is very hot??
what i need???
plz help me:(
actually my cpu fan
Power Input 2.16W (Bottom),
2.52W (Top)
Fan Speed 5000±10% RPM (Bottom)
5500±10% RPM (Top)
Air Pressure 6.6mm-H2O(Bottom)
6.05mm-H2O (Top)
Max. Air Flow 22.98CFM(Bottom)
17.3CFM(Top)
Noise 28.3 dba(Bottom)
34 dba (Top)
Air Volume (CFM) 21 CFM
ya, ur temps are high, that alpha PAL8045 HSF is very good, and so is one other that i cant believe i cant think of the name of right now :mad:
btw, u dont need to type everything in caps lock, it sounds like you are yelling.
