cpu cooling fan intake or exauset?
modgod1618
Northport,NY
i just recently got a tornado93mm for my cpu fan and i had one question...
what should i use it as intake or exaust? i dont know how that stuff works so i need help on this befor i blow my cpu
thx
-MODgod
thx
-MODgod
If you have a duct to the CPU (or a side exhaust fan) then exhaust to prevent hot air from getting to the mobo.
If not, then intake because it cools the CPU more efficiently.
modgod1618 said:
i just recently got a tornado93mm for my cpu fan and i had one question... what should i use it as intake or exaust? i dont know how that stuff works so i need help on this befor i blow my cpu
thx -MODgod
Not sure what your'e saying.
Assuming it's going to be your CPU heat sink fan, blow it directly on the heat sink.
If it's going to be a case fan, you normally blow outward (exhaust). If you already have other case fans +the power supply exhausting, you may want to make a side blow hole aimed at the CPU area. There's no substitute for cool ambient air blowing directly on the CPU.
yes, you get better performance this way, unless you have a strange configuration. i got much better temps on a computer where the psu intake was right next to the HSF by turning it around to blow towards the psu.
