to OCForums!
The drop in voltage between BIOS setting and idle is called vdrop. The drop in voltage between idle and load is called vdroop. Both of these are normal. To get your voltage to stay more in line with your BIOS setting, you have to enable "Load Line Calibration" (or whatever your mobo calls it) in the BIOS. You could also just increase your vcore so when the CPU is under load it will still get the needed voltage.
This works but it will also increase power consumption and heat. Its usually best to leave it off.
So i should enable LLC only? Or what do you you mean by C2D, C2Q?
There is is a difference between the Core i7 and the C2D and C2Q when it comes to Load Line Calibration. It does help on the i7 for certain tasks and applications. It stablizes the Vdroop very well and the i7's work well with it, but the long term effects can kill your CPU because researchers found it spikes voltages at dangerous levels on load. On idle or less stressful use its ok to keep on. The C2D's and C2Q's were more effective with it turned on.
.........Not exactly...
Intel designed their CPUs to droop intentionally, it's a safety feature
LLC is a way for the motherboard manufacturers to cater to the desires of the enthusiast community by disabling droop in a quest for better OCing
And why, you ask, do they do that? Becasue it works![]()
LLC is a way for the motherboard manufacturers to cater to the desires of the enthusiast community by disabling droop in a quest for better OCing![]()
Intel does recommend not using it thoughBut who cares most of us void out warranty the day we get the CPU. Some of us don't even get a warranty
Hang on Archer, I think you're confused....LLC is a feature created by the motherboard manufacturers to bypass Vdroop (Intel's safety feature).....Of course Intel wouldn't want us to use it, it's a loophole
You'll never find LLC on a Dell or HP![]()
Thats true, but the charts are on Antech's review and it shows crazy vcore spikes.
