"CPU Latency Timer" option in BIOS :Enabled or Disable????
QSW
Anyone know what this option is for? Default setting is enabled. Just wondering whether how it will affect stability or overclocking.
Thanks in advance :)
Abit SH6 with 700cC0 @ 1015 , 1.8V
I could be wrong, but I think this had to do more with the P2s than it does with the P3s. If not, start at around 7 I believe and work yourself down if instability is a problem.
Seems like in the P3s that setting is sortv'e hard-coded into the chip and is the same no matter, but I may be confusing it with something else.
