- Mar 7, 2008
Over the weekend I decided to attempt to set up a system to play FFXIV on my 144 Hz 1080p monitor. I thought this should be easy. After much testing, I found framerates varied massively depending on where I am in game. 60fps was easy, but in more challenging areas, going above that was difficult. Do I need faster than 1070 on 6700k? Assuming I needed more GPU, I put two 980Ti in SLI on my R7 1700 system. It was slower. I checked SLI was working, and it was, but GPU loading was lower than expected. I tried full screen, prefer performance and forcing vsync off, all didn't help. Fast forward some more, I found overclocking the CPU helped increase framerates, going from 3.0 to 3.6 increased from low-mid 70's to low 80's. Looking at core usage, there seemed to be one core hit particularly hard, although more than one was used. I guess I need fewer faster cores? Can I increase it enough to get 144fps?
Since then I've moved the 980Ti SLI into a system with 6600k, and that's as far as I got due to other family matters over the weekend. I've yet to test it, but I hope it helps... 4.2 is my easy setting, and I can push further as required. The CPU and one GPU is on water loop, and I can get an additional block for the 2nd if proven to work.
