- Mar 7, 2008
Splitting this off the Ryzen thread to prevent cluttering that up.
Starting from the above comment, I'm curious what instruction set [email protected] uses, and the relative performance between Ryzen and recent Intel. I suspect I'm confusing AVX and AVX2.
I'm not sure exactly what work is being compared. Looking in my project options I only see options to select astropulse v7 or [email protected] v8, so have only selected the latter on CPU. No GPU tasks. Currently running on a Haswell i3 at 3.7 GHz, one per physical core using affinity, it is estimating 2h45m to complete units. I'll add my Ryzen system shortly.
Edit: estimates are now 2h for one unit, 2h30m for the other. I think I'll ignore the estimates and will only use completed unit times.
I run the [email protected] Multiband AVX app on the CPU. So that really stresses and heats up the chip. The 1700X is twice as fast on the AVX CPU tasks as my FX processors. So they did a real good job in optimizing the AVX path in Ryzen. I am crunching a CPU task in under an hour on the 1700X. The same task on the FX 8350 and 8370 take over 2 hours to finish.![]()
