- Oct 6, 2002
- W. Lafayette, IN
Hey guys, here is the system
P4 2.0A @ 2710 mhz, 1.6v
Volcano 7+, Acs3, Modified to sit perfectly on the cpu.
Abit Sr7-8x
I did do some reading in the Abit motherboard forum, and it seems some of the abit boards read temps high, but I didn't find anything specific other than for the IT max7-II I believe.
Running at this speed the temps are:
54-57C full load (prime 95),
42c idle
At stock speed, stock voltage
47-48C full load
41-42c idle
I can feel the heatsink is warm, but not anywhere near 50C. Is the board reading too high or should I look else where? The volcano 7+ is definatly touching the cpu as I removed all the tabs on the mounts to allow it to clear the heat sink mount. I have a side door case fan blowing air onto the heat sink. 3 large fans in the front taking air in, and 2 fans in the back drawing it out. System temp under load is 33c.
Any suggestions?
Cpu runs Prime 95 for at least 4 hours without an error.
Peter
Abit Sr7-8x
42c idle
47-48C full load
41-42c idle
Any suggestions?
Peter
