Diablo (May 14, 2001 12:50 a.m.):
your temps are lower because your system is more efficent with the slower pump the water has more time to cool in the radiator i made a post no one commented on my point proven. YOU CAN MOVE THE COOLANT TOO FAST FROM THE RADIATOR, IT DOES NOT HAVE ENOUGH TIME TO COOL IN THE RADIATOR. .
Well I spoke to soon my temps did not drop with the slower pump. They just took a while to make it back up to 32c. As a further note, I do not use a radiator I use a huge water resevoir contained in my freezer. Thus slower moving water will not benefit me. In addition, system temps as pointed out are not read from the Northbridge and thus would not be affected either way by the flow of water through the chipset block. Though I do agree that if you do use a radiator, slower flow through the radiator is a good thing, with the added note that faster flow across the water block is also benificial. How to keep the water flowing fast across the block yet slower through the radiator is a another problem. One which I don't need to worry about
Now onto the system temp indicator site.
I did a reverse experiment from LimeyGreg. I used a hair dryer. I wasn't able to narrow it down as exact as he but I can confirm that that the system temp reading is taken from somewhere near the lower end of the board.
So now to address the theory of why putting a blue orb onto a your Northbridge causes your system temps to drop and putting a chipset water block on causes them to rise.
Answer: Airflow plain and simple. Though the system temp is not read from the Northbridge, a blue orb none the less pushes more air across your board and thus lowers your system temps.
My system temps raised a bit from 27c to 31c becuase of the reduced air airflow. This is not much of a problem as the main chip that needs the cooling, the Northbridge, is getting all the cooling it can handle.
LimeyGreg can you circle the exact chip that you found to read the system temps and then repost this pic? If you have a bigger picture feel free to us it instead of this one.
[img="[URL]http://plaza.powersurfr.com/MsNath/home/kt7a-raid.gif[/URL]"]
