cpu temp
chojnacki
this is my cpu temp amd sys temp
its a 3.2Ghz intel CPU
CASE OPEN
CPU:42* celcius
Sys: 28* celcius
CASE CLOSED
CPU:47* celcius
SYS: 32* celcius
is this to hot?
wpmegee
Huntsville, AL
You're fine. Up to 60 C is usually safe on the core. Don't know much about Intel procs, but my Barton load is 49-51c.
Don't worry about your temps, oftentimes they're inaccurate anyway- if you're proc is stable, then it's cool enough.
