i want to ask is it possible the cpu at idle run a bit hotter like 5-8c cause the temp outside is up ??
i have 6700k oc 24/7 but when i am idle at 800hz i have like 18-20c and now i have notice 25minimum... I streesed the cpu for 10 min and got 83 max i havent change thermal pase for 3 years,should i change it ?
Ihave set the fan curves in my mobo to run at minimun and when it needed they run more rpms if the sensor read hotter
