what are your guy's CPU tempatures with water cooling, then with water cooling + peltier?
my average tempatures is about 48*C at idle, 49*C when playing UT
im not using a peltier
is my pump to slow?
or is my CPU cube not good enough
warflyr (Jul 13, 2001 06:46 p.m.):
is my pump to slow?
I'm having the same problem. Aquastealth2 kit and my CPU idles @ 48C and about 50 during Team Fortress. I'm thinking about adding an additive to the water but I'm not sure...
im going to call them and try to return the rio pump and get the danner, thatll help some, then maybe put something else int he system, maybe rubbing alcohol (can cool lower than room temp), but there are a few things to worry about with it
