Cpu Temps???
PHILIP1193
England
i finally got my comp up and running just wanted to check temps by you other people who have simalar setup as me!
Ok i have ambient room temp of 22oc, case temp of 17oc, idle temp of 41oc and load temp of 43oc is this ok for my setup below?? or is it a bit high (im talking about load/idle temps) , i have 1 120mm stealth fan on back 1 zalman 92m fan on heatsink and 1 92mm fan in front.
Are these ok for my 3.2 p4c??
Phil
p.s. i got temps from bios of mobo and the got the comp up to load via running 3dmark03 and then booting into bios straight after
PHILIP1193
PHILIP1193
England
ill post a screen when i get home- im at coll at moment.
sorry
then you can belive it for your self.
archilochus
THE Senior FANMAN
Houston,TX-USA
I've seen this happen before on Abit boards...The system temp reads way to low..I use a prog. called Speedfan to get my temp readings..You might give it a shot..Chances are you'll get the same system temp. as it uses the mobo sensor that the bios uses..Run 2 instances of Prime 95 torture and see what your 100% load temp is..:) You'll need to install pr 95 in separate directories, so they don't conflict.. :thup: Run the torture test..
PRIME 95 LINK
SPEEDFAN LINK
* I don't use the auto fan feature of this prog..
archilochus
THE Senior FANMAN
Houston,TX-USA
For temp( ° ) symbol, hold down alt. key and type 0176 then let off of the alt. key..Do this on the far right number pad with, Num Lock turned on..:)
The SP-94 HS has a C/W rating of 0.14,your currently at 0.19 C/W at idle...But that could be the mobo sensors..To test your system temp, take off the side panel and blow a table fans air into the case...test for 100% load temps..The diff. between your load and idle temps seem to be inline, pretty much..But I don't know how your putting a load on the system..:)
PHILIP1193
PHILIP1193
England
i think those previouse temps were wrong i have a idle temp of 39°c and a load temp of 49°c case temp is 28°c. (taken from sis sandra 2004) but i aint sure if the heat pipes are right way around.
I have a chenbro gaming bomb which means the 120mm fan i right next to 92mm fan on heatsink.
I have heat pipes facing towards <------ (back of case) not down left or up the only way it will fit is this way i think. I think they are wrong are they??
Phil
archilochus
THE Senior FANMAN
Houston,TX-USA
You have them in the correct orientation...As long as the loops in the HP's are not at the top....
please don't quote my pic.:)
** Always include the ambient room temp also, when reporting your temps..;)
On the chance the system(mobo/case) temp is still reporting low, take off the side panel and blow a desk fan or simular air into the case and record full load temps..:burn:
PHILIP1193
PHILIP1193
England
My heat pipes are like the 3*** one of left does that mean its best if you have case lying down flat? as mine if obviously a tower and stands up. My ambient room temp is 22°c. I used mobo monitor 5 and it gave me same results as sis sandra 2004 heat wise!
So once again are these naf or ok?
Phil
archilochus
THE Senior FANMAN
Houston,TX-USA
Your good on your heat pipe position..Your temps are good...Might be a little better with a better fan on the HS..These HS's need a higher pressure fan than what the Zalman can provide..A 92mm Panaflo H1A would be a better choice..It would be nice to see the case temp closer to ambient room temp also..Did you ever take temp readings with the side panel off and a desk fan blowing in?
PHILIP1193
PHILIP1193
England
no sorry as i am at coll at the mo so i will when i i get home! Ill post results.
aren't 92mm Panaflo H1A have low cmf's and or are these noisy ones that are high power??
Phil
mtb856
Helping young Meatballs grow...
I would go for the 92mm Delta HHE, from my experience 80mm fan's that are high power are also high-noise... and it's not just noise, it's whiny high pitched noise. :p ick.
The HHE isn't very loud (43dB) and it puts out 72 cfm... compare that to the 80mm Tornado and you'll see why I like it. More importantly, it's 38mm thick... meaning that it's a high pressure( med. rpm) fan and is able to cool the HS all the way to the base. Low pressure fans ( usually 25mm thick and/or low rpm ) just cool the top of the fins and aren't able to penetrate the fins all the way to the base due to . Look at my temps and arch's temps... we both use the same fan. :) Good luck on your cooling.
archilochus
THE Senior FANMAN
Houston,TX-USA
We have diminished their stock..hehe..:burn::) no mas!
It's getting tough...No Panaflo 92mm U1A's or U1BO's..:cry:
Now the HHE Delta's are gone..
I think I'll take a month off.:rolleyes:
mtb856
I'll see if I can mail them and get some faster restocking... and ask if you and I can be their "unofficial" spokespeople :D Maybe that can be my rank when I get enough stars... the unofficial Delta HHE spokesman :D
archilochus
THE Senior FANMAN
Houston,TX-USA
This is the reason, I hurried up and bought mine...I also don't like to recommend things I haven't used...But I had a reliable review on the Delta HHE, IMO..:)
Delta or Sidewinder??
PHILIP1193
PHILIP1193
England
i was after a 92mm one but i couldn't find one :(
thats for that bit on the thickness (as they saying goes you learn summit new everyday) lo l
cheers ill post back if i find one
Phil
