CPU theft!
Intrepid
Boise, ID, USA
I was installing my MCX4000 today and had to remove it once, well when I did, it was hard to pull up, but i did, than i noticed that something was missing from my mobo
the CPU!
it was stick to my heatsink! i used AS3 which i guess has VERY strong suction properties.
BEWARE!
Hopefully all still works after that !
I haven't had that happen with AS3, but when I was testing my water chiller setup I insulated the daylights out of everything.
After one of the factory solder joints let go my temps were a bit higher due to all the insulation.....and the cpu was stuck to the block HARD!
I was a bit surprised that everything still worked after pulling the chip straight out of the socket as well (although I KNEW exactly where it was.....talking a LOT of force was used with mine!!!)
no the whole chip came out of the socket while locked! undamaged. it is, however, getting unusualy high temps but it is now stable at 3ghz, it w2asnt before ???? and also there is a fan somewhere that is to loud and its not the cpu or vid card...i just dont get it! this whole rig got messed up from the moment i put that MCX4000 in. my 3Dmarl score is 3100 now! :cry: I might go to W/C
those are on rheo, both of them. the only fan not on a reo is the GPU fan but i stoped it with my finger and still noise somewhere....
are the p4 levers weak then?:eh?: or are the pins to small for the clip to grab on to.?:eh?:
Well maybe due to the large surface area of the heat spreader.
thats weard :eh?:
The same thing happend to me with my P4. I had used a little to much as3 I think. Both the heatsink and the cpu was lapped so the connection between them was tight. When I removed the heatsink the cpu came with it. No harm done though, it still works like a charm. :)
Hard drive? That the most noisy part in my comp, Maxtor. :/
This is a common problem usually associated with using to much Arctic Silver thermal paste, using too much will cause the CPU to 'stick' to the heatsink or waterblock ;)
