CPU won't acquire WU
Suppressor1137
Has been stuck on Ready since last night.
Set to -1 atm, but it won't aquire a WU, Says Downloading, ETA unknown, Credit Unknown.
I7 6700k.
Description says cpu:7. Is it trying to use 7 threads?
tom_ozahoski
Yes 7 threads rarely work right, odd numbers of 7 or greater cause issues. Lock it to 6 threads or do two cpu's of 4 and 3 respectively.
JrClocker
AKA: JrMiyagi
It does but you may end up starving your GPU of resources and slowing that down by more than the cpu folding gives you. What goyu are you running?
Yes - if you are GPU folding on the same machine, it's best to have 1 core (not thread) free for each GPU.
don256us
Uber Folding Senior
Actually, one thread is enough but it still needs to be an even number. 8 threads total - 1 for the GPU = 7 threads but you need an even number so drop it down to 6 on the CPU. Works like a charm.
