Does anyone have any idea why cpu-z isn't reading my vcore? I have it set to 1.34, I have the Asus z170 Deluxe and the ai suite reads it at 1.344 and it goes up to 1.360 under load. @ 4.6ghz. Stock this board has high spikes in voltage and someone else with the maximus viii hero said he experienced the same thing. High voltage spikes with everything at default. So with a manual oc the voltages stay in check but cpu-z doesn't even read a voltage at all it doesn't recognize my gpu, in the memory section it's reading my memory speed at 1600mhz so 3200mhz dual channel which is where it should be but then in the next section the spd section theres nothing at all same with the graphics section. I already uninstalled it once with revo and removed leftover files and registry edits and reinstalled and it's still where it was it's weird. anyway I'll go back into bios and see if I hit something i shouldnt have and I'll post if something changes. Thank you
