- Aug 13, 2010
Update: 6/12/2013
I have installed my U120eXtrem1366RT using Artic MX-2 paste and re routed my fans correctly as advised below. This lowered my temps substantially. I also ordered an OCZ Vertex 4 128gb SDD. I should receive this in the next few days and look forward to the increase in load times!
I have 3 new questions:
1. I have done nothing in the bios for my ram, can someone point me in the direction on how to get them operating at the called for timing/voltage? The OCZ ram call for 10-10-10-30 1.65v
2. What is the best way to mirror my current raid 0 setup to my new SSD? Or is a clean install better?
3. I'm currently using the gigabyte "smart6" OC utility on "twin turbo" which pushes my processor from 2.8ghz to 3.5ghz. Is this safe? My idle temps are 40c to 45c with a tjmax of 100c. I've read a few articles on OC and am still not comfortable with it on my own so I've used this utility. Is it better to continue reading and become comfortable with doing it myself?
I've also noticed a lot of people running dual channel memory, has tri channel become not important?
Case: Antec 900 Black Steel ATX Mid Tower w/ USB 3.0
MB: Gigabyte GA-X58A-UD3R LGA 1366 Intel X58 SATA 6gb/s USB 3.0 (rev. 2.0)
GPU: Gigabyte GV-N460C-1GI GeForce GTX 460(Fermi) 1GB 256-bit GDDR5
PSU: OCZ GameXStream OCZ850GXSSLI ATX12V v2.2 EPS12V 850watts PS
Processor: Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130w
HD: 2x RAID 0 WD Black WD6401AALS 7200rpm SATA 3.0Gb/s
Cooling: Stock (I have Thermalright U130eXtrem but it doesn't fit that good)
Memory: OCZ Gold 6GB (3 x 2GB) DDR3 2000 (PC3 16000) Low Voltage OCZ3G2000LV6GK
Dedicated USB drive for ReadyBoost
Logitech G510 keyboard
Logitech G9x Laser Mouse
LG 22" LCD 3000:1 Digital Fine Contrast - 2ms response time - DVI cable Connection
I'm running gigabyte cat6 to a gigabyte router to a gigabyte comcast modem with an upgraded speed. Everything is plugged into a power stabilizing surge protector. I have the fans bring the air in from the front and exit the big top fan.
I want to upgrade to an SSD as my primary drive and change my Raid 0 setup to just storage. I've also thought about adding 6gb more ram (12gb total) and adding a second GPU (SLi). In the near future I will buy an all-in-one liquid cooling solution for the cpu.
What are your recommendations? Also I'd like to stress test and do benchmarks. I just downloaded Prime95 and will run it tonight, any other ideas? Once I get my setup perfect I will want to overclock.
Thanks
Thanks
