Would like some feedback on this build whether positive or negative, doesn't matter. My indecisiveness here is the GPU, not sure if an upgrade to a 980/980Ti is worth it at this point since this 970 FTW+ performs and clocks so well. My monitor is a Dell 1440P 27" 60HZ still in the box as the man cave/office gets finished. Also love the Fractal Define R5 case, but seen some reviews where users stated issues mounting a rad up front....? So have been eyeballing the Phanteks Evolv ATX case as well?
And then the PSU, I know it's overkill for a single GPU solution but want to leave myself open for SLI in the future if the next gen cards are not necessarily worth it and good deals can be found from those that do decide to upgrade......
https://pcpartpicker.com/user/Evil-MOBO/saved/#view=kj9gXL
Thanks
Thanks
