- Jun 23, 2013
- MN United States
If I have the 390 in already can I just drop in the 290 in the next fastest PCI slot? I dont see why id have to mess with drivers.....???
If I have the 390 in already can I just drop in the 290 in the next fastest PCI slot? I dont see why id have to mess with drivers.....???![]()
I asked the same question a few months back and was told CF won't work with different generation GPUs. Being the 290 still needs a bridge to CF and the 390 does not, I am leaning toward that information being correct.
-Seabee
290 doesn't need a xfire connector. They xfire fine (I have done it). They are the same generation GPU with more ram slapped on.
Bingo.
It is worth noting though, you won't be able to utilize all the vRAM on the 390 when in Crossfire.
I would be curious what happens with DX12 multiGPU instead of xfire.
It will depend on game developer support.
DX12 in itself allows for ram sharing between the cards however. I am curious if it will see 8GB or 12GB. That part shouldn't depend on game/dev.
What's your whole system?
They are the same GPU, basically, so they can be run in Crossfire.
If you want to be technical, the 390 is an upgrade to the 290.
Do you remember (back in the days) when you could run 2 ATI/AMD cards. All they had to be was from the same Series 38xx, 48xx, 58xx. If you paired a faster card with a slower one, the faster one would drop to the slower ones speed.
With this new Cross Fire Over PCIe, that NO LONGER WORKS. YOU have to MATCH CARDS from the same GPU SERIES to get Cross Fire to work. I tried to CF a 290 and a 290x, the system refused to see the second card.
Well, news to me, for some reason I wasn't aware it worked.
AMD is far far far more loose on xfire than nvidia is with SLI.
The 390 is as similar to the 290, as the 290 is the 290x. There are changes all around, but they all have slight differences. They can all be crossfired together.
Same as an r9 380x and an r9 285 can be crossfired. Same base GCN core is all thats required to crossfire.
290+290x works in crossfire. I had a quad setup briefly that was mixed and it worked. (During the time I was mining)
