Crucial Ballistix 512MB LED PC2-5300 only $71
ghost_recon88
Senior Jedi Master
Michigan
Yes, I can't believe it ether. I was searching eBay for DDR2 and I found this seller. He has Crucial Ballistix 512MB LED PC2-5300 667Mhz DDR2 for only $71 a DIMM or Crucial Ballistix 512MB PC2-5300 667Mhz DDR2 Memory for only $61 a DIMM. I looked on newegg.com and they didn't even have the LED stuff and the regular Ballistix was $138 a DIMM. This guy is charging almost 50% less! Here are the links
LED Ballistix $71:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=44938&item=6777783427&rd=1&ssPageName=WDVW
Regular Ballistix $61:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=44938&item=6777783541&rd=1&ssPageName=WDVW
Man, I already picked up two of the LED ones but I might get more just because they are so cheap!
edited by sss, user banned and his link referals were altered
Will this work on an NF7 mobo? I pray it does!
The DDR1 one will but not the DDR2.
Is this ram any good? Some of the timings look kinda high.
http://cgi.ebay.com/ws/eBayISAPI.dl...6777759116&rd=1
for 1gig of ddr1 for 125 bucks. Awesome deal...
Anyone know the overclockability of this stuff?
1 gig sticks usually don't oc as far as 512 sticks. Plus unless you are planning on buying two you would lose the duel channel.
