Crucial recently added Sport LT series to its DDR4 memory kits. Ballistix Sport is available on the market for couple of months and it seems it's popular. LT version is slightly improved. We have "digital camo" heatspreaders and black PCB but also easy to use memory profiles which should work regardless if we use XMP or standard SPD settings.
Crucial Ballistix Sport LT DDR4-2400 CL16 has only one XMP profile which is enough for lower clocked memory kits.
Below you can see results at XMP profile which is about the same as SPD ( AIDA64/CPU-Z windows with profiles ).
Crucial is a Micron brand so we can expect to find new Micron IC inside. Similar to Crucial Elite reviewed couple of days ago, also Sport LT is based on IC designed to work as DDR4-2400. Elite series will have similar but better selected memory chips which gives higher chance on higher overclock.
