Today I have Crucial Ballistix Tactical 4x8GB DDR4-3000 CL15 kit which is actually four single sticks with BLT8G4D30AETA product number. Here is link to the product page: http://www.crucial.com/usa/en/blt8g4d30aeta
Memory is designed to work on Z170 and X99 motherboards. Since there are 4 sticks then I will test it on ASRock X99 Taichi with i7 6800K processor.
Memory works perfectly stable at XMP 3000 profile so 15-16-16 1.35V
Crucial is a Micron brand and most their DDR4 kits are based on Micron IC, however this one is based on SEC IC - K4A4G085WE-BCPB. It's the first time we see that Crucial decided to release 3000-3200 memory kits ( Tactical is max 3000 while Elite is 3000 and 3200 ). It just proves that something has changed and Crucial is sure about memory stability at 3000-3200.
Here are screenshots how CPU-Z and AIDA64 see this memory. The latest version of Thaiphoon Burner is showing unknown memory manufacturer but we can read IC model which is as I mentioned K4A4G085WE-BCPB so it's Samsung.
Modules are 8GB dual rank so in some applications should provide better performance than single rank modules.
