This may not be a problem but wondering if anyone has experienced the following...
x2 128Mb Crucial PC133 CL2 on ASUS A7V133. When allowing SPD to auto detect memory timing in the BIOS it will detect CL 3 instead of CL 2 if you raise the FSB higher than 106mhz. Even if you drop the ratio to 1:1 i.e. setting the memory speed at the same speed as the FSB.
I don't know if this is an issue as I can manually set the timings to CL2 when setting the FSB higher than 106Mhz and don't seem to experience any problems. Note this happens on both DIMMs, installed separately or together, therefore I doubt there is any problems with the
memory itself.
Any ideas?
Greg
memory itself.
Any ideas?
Greg
