CUSL2 Overclocked WELL! but whats worng with my agp..........
W
will
Guest
hellllllllo.....someooooone please help me....i just bought a asus cusl2 board and flashed the bios to version 1003..what happen was i over clocked it to 1024mhz..it worked fine...it was set at 100:100:33 the problem now is that my AGP card cannot be set to 4x anymore..however when i clock it down...it went back to 4x....someone help me...is this okay? maybe this will be better or equal to 4x on original fsb?
I don't have a real good understanding of AGP x2 and x4, OK? AFAIK, x4 vs. x2 on an Intel chipsetted mainboard is almost a non issue. There's not enough of an improvement in using x4 over x2 to lose any sleep over. OTOH, this is definitely a concern with Via mobos.
Will,
I also have a Cusl2-C mobo, and have found that Asus disables the 4X anytime you go over 140 FSB, I received the work around for this from eddie (thanks eddie). I will shoot it to you via email.
I believe it's refered to as a stability problem at anything under 140fsb, then above 140fsb it's disabled. Sandman, were you the one that sent me the fix when I asked for it on http://www.cusl2.com ??
