Hello, looking at building my first custom loop and was trying to figure how to control my pump and radiator fans without using an external fan controller. I have the VIII Hero motherboard that has a w_pump, cpu_fan, t_sensor (three of them), and chassis_fan headers. According to the manual, these are all 4-pin PWM headers.
Is it possible to input a temperature sensor into my loop and connect it to the t_sensor header on my motherboard and have my PWM radiator fans and pump speed regulate based off of this temperature sensor source and regulate based on the fan curve set within the BIOS via Q-Fan?
Ideally, it would be connected like this:
Temperature sensor connected to t_sensor header.
Water pump connected to w_pump header.
Radiator fans connected to chassis_fan 1 running in PWM mode.
Source for radiator fans and water pump is t_sensor.
I don't think the cpu_fan header source can be changed from cpu to t_sensor or can it?
