Hello everyone, it's been a while I am doing researches about the chances of building a custom waterloop in my mini itx case.
My case is a Raven RVZ01
The case by manufacturer could host a custom cpu gpu loop (on their website you can find some recommendations),my concern is that this particular case is really small and very difficult to find all the items,especially pump and reservoir.
The manufacturer recommends a bitpower reservoir which you could mount on the 3,5" hdd slot situated on the power supply bracket (as shown on the picture attached),unfortunately bitspower does not produce this reservoir any longer and no other manufacturers do 3,5"reservoir, and this became a problem for finding the pump as well. The recommended pump is a laing ddc (the old model whit the mounting holes on tge side of it) cause this can be screwed in the 2,5" ssd space on the gpu support bracket,as shown on the picture
After some research (unfortunately nothing really came up) I chose a combo pump/reservoir (which is actually less painful) in particular these two model I'll show you: tge first one is this alphacool product
If I buy the ddc pump and mount this reservoir top I should manage to fit the space between the gpu bracket and the power supply, but only in the case it does not need a pump top, but only this reservoir mounted straight on, so that I can screw the combo on the gpu bracket. Unfortunately I did not understand whether I can mount this reservoir straight on or I need a top also (this solution could not fit in)
Otherwise I considered as alternative this pump reservoir combo by xspc (with a D5 pump included) but I cannot understand if the base can fit the 2,5" space on the gpu bracket.
Could you please help me regarding this or tell me any compatible solution I haven't considered yet or stumbled across? Thanks in advance, cheers
