- Nov 22, 2009
Heres my idea, a tower. So far its an idea, i might do, might not. Might start next weekend. Not traditional ones like have lots of depth and height. But my tower will be very tall comparing to most cases, but will not have a lot of depth, length, or width. It's basically this but a tower. The shape of it is how the world trade centers looked like. A tall square.
Here are some pictures i did in google sketchup. The external will be a wooden color, probably something close to mahogany but lighter, maybe rosewood. The blue surfaces will be probably 140 mm blue led fans. The gray surfaces on the side will be cast acrylic. The whole case will be made out of wood. Now since I don't have a lot of depth. The hdds will be hanging vertically just below the top fan.
I will move my sig rig to this case. Space for 5-6 hdd's hanging vertically from top, right below top fan.
The length and width will be 10" by 10". And a height of 2.5 feet should suffice.
Hdd's right on top, mobo beneath that, power supply beneath mobo, and on the bottom dvd drives for weight and stability.
3x 140mm fans in front, 1 140mm on back along with 1 120 mm, 1 200 mm on top. The google sketchup is true to scale.
Parts list
Power/reset/usb/esata panel
wheels
200 mm top fan
1 lamptron 4 channel fan controller
1 Thermal-Star LCD Media Panel 7-in-1 Card Reader / Fan Controller / Temp. Display
1 120 mm blue led fan, comes with switch that turns off led, if u can find similar tell me
24 pin extension
nuts/screws standoffs
3m tape
windows kits x2
sound dampening kit
one wooden grills
200 mm grill
hdd led
4 times 140 mm blue led fans
4x 140 mm fan grill
Parts list
wheels
200 mm top fan
24 pin extension
3m tape
windows kits x2
sound dampening kit
one wooden grills
200 mm grill
hdd led
4x 140 mm fan grill
