- Sep 24, 2001
Hi, I've been lurking arround this board on and off for a while now and I've finally decided that I want to build a water cooling setup for my computer. It's a PIII 667MHz currently running at 700MHz. I ran Burn6 on it last night and the external thermometer(sp?) hit 65*C before I shut Burn6 down. Now what I plan to do is simple. I have a heatsink that I plan on using for the base of the block. I was thinking of putting a Plexiglass case arround the heatsink to complete the water block. My input would be in the centre of the top of the block with two outputs on one side. I have a BMP image that I'll attach to give you something to look at so I make some sense. Now what I would like to know is if you feel that it will work? Thank you for your time and any advice that you can give me.
