- Sep 25, 2015
I'm really, kind-of, almost thinking about maybe doing a custom loop for my main PC.
I'm looking to you guys for help!
The stock cooler on my Titan X Pascal is...well...pretty loud. (NVIDIA should be embarrassed to put this short of thing on a $1200 card). If I run the card at stock speeds, the cooler is sort-of silent. But, you don't by a $1200 card to have it run at stock speeds!
Right now, I can get a sustained GPU boost on the card of 1950 MHz. However, at the penalty of 85 C GPU core temp and the fan running at 100% (pretty loud).
So - my main reason is to quiet this thing down. However, my brain is all over the place.
My first step is going to be a new case with better air flow (settled on a Corsair Air 740...will but will wait until it comes into stock on Amazon...as I'm not paying $25+ shipping from Corsair.)
My next step is going to water cool the card...somehow:
Option 1: AIO Kit for Titan X Pascal
---> I have an EVGA 980 Ti Hybrid. This is also a 250 W card, and runs mid 50 C GPU temperature with 28 C ambient. Not too shabby, but not great. However, it's quiet.
---> EVGA is supposed to be coming out with a hybrid kit for the Titan X P...but no date...and I can't wait forever (the thing is loud).
---> Many folks have used the EVGA 1080/1070 hybrid kit, with a few mods to the kit, and had it work well.
------> EVGA is currently out of stock...this is the ONLY reason I have started to think about custom loop cooling.
---> If I go this route, I have to get a smaller AIO for my CPU to fit 3 radiators (CPU, 980 Ti, and Titan X P) into one case.
------> The 280 mm radiator I have for my H110i is too much for the CPU anyway...from reviews, I think I can get away with a thick 120 mm, in push/pull fans (trash the stock Corsair ones).
Total cash outlay: $347, maintenance: very little (clean dust out of rads)
---> Hybrid kit: $140 shipped
---> New CPU AIO: $95
---> 4 ML120 Maglev Fans: $112 (2 for CPU AIO, 2 for Titan AIO)
Option 2: EK Predator 360, with GPU Block
---> I think this will fit in the front of the new 740 Air
---> Pre-filled, would order pre-filled GPU block
---> My usual usage of the PC is folding and gaming...neither of which max out my CPU usage.
---> Titan pulls about 275 W, and CPU pulls under 100 W...so 375W
---> A bit much for 360 mm of radiator, but GPU temps should be better than AIO.
Total cash outlay: $505 + EK shipping
---> EK Predator 360: $220 + shipping
---> EK Titan Block (prefilled, with QD): $166 + shipping
---> EK Titan Backplate: $35 + shipping
---> 3 ML120 Maglev Fans: $84
Option 3: Full Custom Loop
---> Go for broke...5 x 120 mm of rad...more than enough to cool 375 W.
---> Should be able to run the fans on low.
---> 360 mm radiator as intake, 240 mm radiator as exhaust above CPU
---> 980 Ti Hybrid as exhaust on back of case
------> Is this configuration OK????
Total cash outlay: $942 + EK shipping (holy freaking fittings cost batman!!!)
---> 360 mm (Hardware Labs Black Ice Nemesis 360 GTS): $68
---> 240 mm (Hardware Labs Black Ice Nemesis 240 GTS): $64
---> CPU Block (EK-Supremacy EVO RED): $82 + shipping
---> EK Titan Block: $136 + shipping
---> Res/Pump (EK-XRES 140 DDC 3.2 PWM Elite): $150 + shipping
---> Pump Mounting Bracket: $14 + shipping
---> Compression fittings (EK-ACF series): $100 + shipping
---> Angle adapters / extenders / plugs(EK-AF series): $125 + shipping
---> Tubing (PrimoChill Primoflex Advanced LRT 15.9/9.5mm, 3m, red): $28
---> 5 ML120 Maglev Fans: $140
I have read many horror stories about custom loops. But it seems that you only hear the idiots on Google searches and not the good of things.
The plumbing looks simple - especially if you use compression fittings and flexible tubing. The only real pain-in-the-butt appears to be the initial radiator cleaning.
The next thing that worries me about a custom loop is what to add to the water. My internet research has shown differing opinions on just about every aspect. What I do know is that:
1. Algae growth is bad.
---> Silver kill coil or additive to the loop?
2. Corrosion is bad.
---> De-ionized water will eventually become ionized...and different metals will do what they do and be a battery...and cause metal A to be removed and deposited on metal B.
---> What do you add to the coolant to prevent corrosion?
---> How often to flush?
3. How does my parts list look for the custom loop?
