Cut for 120mm fan...
Oneiron
Trondheim, Norway
I have just ordered 4 120mm fans I will install in my tower. I need some schematics or something so that I can draw where to cut on my case so that the 120mm fans will fit. Do any of you know where I can find such a thing on the web? (something printable to draw by would be great!)
thx :)
Diggrr
Underwater Senior Member
Here ya go.
Scroll down the page for them, and there's also a description on how to use them.
Ciao bud!
Iron Hawk
Groton, CT
to cut my 90mm fan holes i went to the store and bought a hole saw that cut a hole about 90mm (it was for 89mm or 3.5inches) after drilling the holes i grabbed a fan guard and placed it down on the hole and marked where i needed to make the holes for the screws.
The fan guard (or the fan itself) is allready a template so it shouldnt hurt to use it for that.
you can see my fan holes here:
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=74237
Oneiron
Oneiron
Trondheim, Norway
Diggrr said:
Here ya go.
Ciao bud!
Thx, but as I said I need one for 120mm... and they don't go higher then 92mm. :( (I guess I could make one myself from the 92mm one, but I just want to make sure I get the correct sizes!)
Diggrr
Ooops, sorry, I didn't stop to read it.
Try resizing the drawing with a paintshop type program. The outside square should be about 4.72 inches.
Crop the image to the outside of the square, then resize.
Oneiron
Oneiron
Trondheim, Norway
Iron Hawk said:
USE YOUR FAN AS THE TAMPLATE!!!
I DON'T HAVE THE FAN YET!!
A friend of mine does this kind of thing for a living, and he is going to do it for me. The problem is he has to do it on tuesday, and I get my fan on wednesday. See my problem? If he can't do it next week, I'll have to wait until he gets back from holliday in 2 weeks. :(
Diggrr: ok, good idea. I'll try that. :)
