Cutting holes (a newbie question)
BoBo007
Rochester NY
If you really want to do it with out power tools,
you can do it with a "nibbler" tool, it will be slow and you'll be sore when your done !
Hoot
Inactive Moderator
Twin Cities
If the cost of a hole-saw that size causes sticker shock, You can nibble it out with a nibbler like the on radio shack sells. It will be a lot of work to nibble by hand, but a lot cheaper than a large hole-saw. Tip: wear a glove on your hand. it helps prevent a blister on the webbing of your thumb.
Hoot
jboy
Near Berkely, California
I agree on the nibbler. One anvantage being that you dont have to remove everything from your case to cut the hole, the way you do when you're a'drilling and a'grinding. Dont even think about trying to use the latter method to work on your case with the components in place. I tried to do this awhile back , masked off all the components with plastic sheeting and masking tape, but the metal powder debris filtered thru and got into the open circuitry on the back of my hard drives. No permananent damage done, (thank'ya Jesus), but definitely increased my adrenaline level when things came up totally dead. You do have to drill a 3/8 hole to start the nibbler, but if you back the hole with something to catch the debris, and drill at a slow speed, you shouldn't be spraying metal around inside your box. Make sure you remove all the little slugs of metal the nibbler generates, or you'll short something out for sure..
nikhsub1
Unoriginal Macho Moderator
Los Angeles
Yeah a nibbler will work with LOTS o effort, the cleanest fastest best way IMO is a holesaw and drill.
Robbiem01
If you plan to get into cooling as a hobby for a few years and maybe even some case mods it will be worth your time and money to get a dremel now. Make sure you get the one with the cord though. I got the cordless and I cant do much before recharge but while its on its great!
Hoot
Inactive Moderator
Twin Cities
The one on the side you want blowing nice cool air into the case, down upon your heatsink and components. The one on the top should probably draw air out.
Hoot
Robbiem01
every case has different airflow, obsticles and such. The best thing to do (although takes aobut an hour) is try all the combinations. See what gives you the best results. I read that with the Alpha 8045 heatsink it works better to point fans to blow away from it but I saved 10*C by blowing at it because I have a side intake fan. Just goest to show you never know till you try.
