D5 PUMP SEAL
caddi daddi
Godzilla to ant hills
I grabbed out my 9590 rig i have retired to the storage room.
the xspc pump/reservoir is peeing like a grand baby when I have my sunday go to meetings on, all over my desk!!!!!!
it's leaking out the wire hole.
I have installed three seals......
I roll the seal around the pump and shove it home and tighten the locking ring good and tight.
any idea what the heck I'm doing wrong?????????
I do lube the "O" ring with furniture wax.
Lochekey
Senior Pink Member
Did you buy the correct replacement o-ring? I found that there is 2 or 3 different ones listed on Amazon and they all have slightly different ODs on the ring thickness. Ran into a problem with this a while back because the one I bought was to thick and would not allow me to seat the housing correctly against the pump.
caddi daddi
caddi daddi
my seals have all come in the kits or the computer houses.
