- Jul 12, 2002
- Columbus, OH - GO BUCKS!
Ok, his is an old Micron 450 MHz PIII, with 128 MB of SDRAM (not sure which, guessing PC133) and a decent 12 GB harddrive. Its gotta a lot of crap on it that just needs to go (well, ok, most of that was MY crap that I never got around to deleting after I built my first comp...)
I'm thinking if I want this thing running nice and quick so he can do work with no problems, I'd:
1) re-format the harddrive, reinstall Windows 98
2) get a cheap soundcard, disable onboard sound
3) clean up the case, rewire the insides, add another fan (it only has one exhaust fan)
4) get more RAM, like another 128 MB stick
5) replace the ol' TNT2 with a GF2 mx or something...
What else should I do? Is there anything more pertinent that I need to address before starting? I was planning on spending around $100 with this upgrade/cleanout. How do I determine what kind of ram is in the system? Also, should I reinstall Windows 98, or can this system handle something a little more demanding (read: better), like ME, 2000, or even XP Pro, which I have on my comp.
Thanks for you help in advance.
